Scan to folder after Win 10 upgrade
  • sx633
    • Sep 2011
    • 49
    [Misc] Scan to folder after Win 10 upgrade
    Customer has just upgraded to Windows 10 (from 7) and claims that since then he can't scan to folder from irADV2030L (with i send kit fitted)
    I know it used to work, but I also know he is a bit of a fiddler and can't always believe everything he tells me.
    On further investigation i found that the PC can ping the MFD but the MFD can't ping the PC.
    Likewise the PC can print to the MFD but when browsing network from MFD I cannot see PC.
    This is only a home network (barely even a network) One PC , one MFD and an EE router.
    MFD will ping the router. Customer also runs Norton 360, could that be blocking incoming connections ?
    Anyone else had issues with Windows 10 upgrades ? SMB version maybe ?
    • 16083
    Re: Scan to folder after Win 10 upgrade
    WINDOWS 10 has much issues
    Drivers need to be Updated--as of 9/3/2015
    Patches for Fierys/Servers
    Some Windows Based Fierys not 10 Supported
    Canon Software Support for Microsoft Windows 10 Operating System
    • kuby
      • Oct 2007
      • 1408
      I agree with teckat - too many issues. Had a customer upgrade their PC to Windows 10 and found out somethings do not work anymore. Had to roll them back to Windows 7.
      • Gbr
        • Nov 2011
        • 50
        you can try checking if windows is somehow started blocking homegroup members sharing options. option used to be in control panel -network - advanced sharing setting.
        also all of the usual; could be changed.
        -usernames and passwords (different username seen from command prompt )
        -network discovery
        -permissons - users
        -firewall and antivirus
        -host and file paths .. ( If host path consists of it's IP adress check that router DHCP has not changed the computer adress)
        Do you get send error number
        • sx633
          • Sep 2011
          • 49
          It turned out to be Norton taking control of the windows firewall !!!!
            • 8165
            Uninstall Norton, complete waste of money, time & Windows resources!
            Windows comes with free intigrated antivirus software & has done since win 7 (microsoft security essentials or windows defender)
            โ€‹
            • soyemiade
              • Oct 2013
              • 3
              Reconfirm the user's credentials such as password and username.
              • vickyhanif
                • Mar 2014
                • 14
                Even I faced the same problem on windows 10 with McAfee and Eset. Problem is not because of windows its because of auto updates of anti viruses. Just disabled the firewall n everything was working.
                Sent from my Infinix X506 using Tapatalk
