Canon 5000d
  • iQUISMO
    • Jul 2008
    • 19
    Canon 5000d
    We recently bought a 5000d for one of the small offices in our warehouse which didn't come with a netcard. so i purchased a NIC on ebay and installed it, works fine, except i found out that the copier doesn't have PCL/PS installed. I have the SST, updated the software, with no luck, does the copier require hardware for PCL/PS, and IP printing? thanks!
  • 555
    • Jun 2008
    • 45
    that nic should have came with a network boot rom as well ,the copier comes standard with a copier only boot rom. both have to be replaced to be able to print . in service mode check versions : should be (boot n) not (boot c)
    • anothertech
      • 1766
      Yeah, the NIC's are easy to find. It's the N boot rom that lets it print.
      After you get the N boot rom installed you'll need to reflash the system software to the N version.
      You cannot flash the boot from C to N.
      • yourownfree
        • Dec 2007
        • 474
        dont forget the extra memory needed 64meg
