C3220 Windows8.1 can ping and accessUI - stalled
  • Toner Boy
    • Aug 2007
    • 366
    No printing
    Tried PS/PCL5c/UFR - checked set to 0 for printer type - Driver installs fine (all of them) but try's to spool job and stalls -'printer busy or error'
    Tried Sharp driver to same port - same symptom
    Tried RAW 9100, LPR and 'print', LPR and PRINT, disable SNMP
    Also tried Direct Print through UI, says 'cannot use Direct Print', re-seat NIC, behaves the same with 2 similar PC's.
    Any thoughts other than System Software reload or pipe bomb?
    • 16083
    Re: C3220 Windows8.1 can ping and accessUI - stalled
    Originally posted by Toner Boy
    No printing
    What is set up_?
    ImagePass C2 (no UFR )
    or Multi Pdl Kit_A2 ?
    What error_?
    Did u just install 8.1_?
    • Toner Boy
      • Aug 2007
      • 366
      shows
      PCL and UFR - no C2, no box on back -INT-CON set to 0
      New client, no real history-they just got the machine
      I did not see Mulit-PDL Kit A2 listed, only checked through the counter button and system check
      I assumed it was installed or the driver install utility would not have found it?
      • KenB
        Geek Extraordinaire
        • Dec 2007
        • 3944
        This goes back more than a few years, but an easy way to check if the printer option is installed is to check for the presence of AppleTalk. (Crazy as it may sound.)
        If it's not there, the option is not installed, or really messed up.
          • 16083
          shows
          When the Multi Pdl Kit is installed if has a UFR Board (Ultra Fast Rendering Board) installed in the side slot/ This board is installed in the slot on the Main
          Controller underneath the Ethernet PCB.
          & a "N" Network Boot Rom
          • Toner Boy
            • Aug 2007
            • 366
            Thank you all, I'll check again when I'm out that way. There was a board directly under the NIC but I did not check for the boot ROM version.
            • disam
              • Sep 2008
              • 64
              Hi Toner Boy
              you have written: you dont see the Multi-PDL kit a2 and also on the title only C3220
              is this device a iRC3220 or a CLC3220?
              regards
              • Toner Boy
                • Aug 2007
                • 366
                Machine is iRC3220
