Ir3570 exit sensor assembly
  • mrfuser
    • 1622
    Anyone know a part number for the assembly that has the exit switch in it for the 3570? Client has one that the switch is binding on and showing jams.
    thanks
    k
  • canonbundy
    • Jun 2012
    • 607
    Re: Ir3570 exit sensor assembly
    thanks
    k
    Jam code? Exit could mean Fuser, 3Way Unit or Finisher.
    • mrfuser
      • 1622
      As I said the switch, last one as exits, no finisher, sticks. I can physically move and feel it sticking. Looks worn where shaft sits inside unit, this need replacement.
      • copier tech
        • 8172
        Here's the parts manual hope it helps.
