IRAC5250 No Yellow
  • copier tech
    • 8131
    [CQ] IRAC5250 No Yellow
    I found a broken yellow drive coupling, in the rear on the machine (see pic) has anyone else seen this part break? & how does one replace it, looks a nightmare trying to drop in the pin into the new coupling, even with the ITB & drums unit!?
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5007
    Re: IRAC5250 No Yellow
    I am afraid that you will have main drive unit on the floor.
    • copier tech
      • 8131
      Oh really, I cant fit this part with the main drive still in the machine!!!!?? Thats annoying
      • dan7777
        • Dec 2012
        • 680
        I have replaced one and the other tech about 3. Some are easier to reach. Put paper back there and carry and extra pin. It is doable. Take drum and itb assemblys out and have some one with a long arm reach in. I thought I was going to have to replace more but so far not. No need to remove drive assembly. Just hold your mouth right when you put the pin in. The kit has all the parts you need but don't drop pin or carry extra one. Same pin as the new style coupling has. Not easy but doable. Taking the door off makes it easier. Just awkward!
        • copier tech
          • 8131
          Awsome thanks, looking at it I thought it must be doable!
          You mention "a kit" what is this part number please? I've just ordered the two coupling parts & the pin (10 of each)
          • dan7777
            • Dec 2012
            • 680
            FM4-8387-000. Same parts you ordered. TP11 163b[1].pdf
            • copier tech
              • 8131
              Cheers Dan for the pdf thats a great help!
              Are you from Bristol, England? If you are this machine is in Lewins Mead, BS1, you may know it!?
              • dan7777
                • Dec 2012
                • 680
                Bristol, Tennessee, USA
                • copier tech
                  • 8131
                  Oh, a few 1000 miles away I guess!
                  • khattab.al.masry
                    • 212
                    I hope the following attached file help you.
                    • dan7777
                      • Dec 2012
                      • 680
                      A few, ha ha. The older I get the less I want to travel, so guess I will not visit for a while anyway. I keep telling myself I will work past my retirement if they let me but we will see.
