IR 330S adf jamming
  • Gar the pilot
    #16
    Re: IR 330S adf jamming
    I need part # for Feed tire Kit, and exit sensor. Also are these parts still avail??
      • 23010
      #17
      I have no idea what is and what isn't available, but these are the DF rebuild parts I used. They do not come as a kit. You'll have to order each item separately:
      2... FF5-5191-000..... Bottom Feed Pickup Roller
      1... FB3-5637-020..... Delivery/Top Feed Pickup Roller
      8... FE6-3059-000..... Flat Separation Belts
      4... FB3-5702-000..... Ribbed Separation Belts
      1... FG6-2176-000..... Separation Roller Assy
      1... FF5-5181-000..... Front Flapper
      1... FF5-5202-000..... Rear Flapper
      Also if the separation adjustment needs to be done you'll need a spring scale. This post covers that topic:
      http://www.copytechnet.com/forums/ca...tml#post370826
      • teckat
        • 16083
        #18
        Canon DADF A1 Doc Feeder Parts
        • teckat
          • 16083
          #19
          Canon DADF A1 Belts
