IR 330S adf jamming
  • Gar the pilot
    • Aug 2025
    IR 330S adf jamming
    I have an ir330s with a ADF that jams intermentantly at the exit with paper out about 1". Makes me think the exit sensor is the problem but as I work on mostly Mitas I second guess my self on these Canons. It also could use new feeder tires but my manual only covers the copier not the adf. I have cleaned all the tires, the glass, and have blown out the sensors. Sometimes it will feed 20-30 originals repetedly with no problem then it will jam every/every-other page.
    Thank You
    G
  • Jessetech
    • Mar 2014
    • 38
    Re: IR 330S adf jamming
    Chief, I have ran into similar problem, it's the adf door that doesn't close tightly, customer put 1 reem of paper on top and no trouble lol....but yes rollersdo help use oem seperation
    • teckat
      • 16083
      Thank You
      G
      may be caused by the dislocation of the Delivery Sensor Flag. Check the white flag for proper orientation and movement.
      Jam Codes
      Following is the adjustment procedure from the DADF-A1 Service manual.
        • 23010
        What jam code? =^..^=
        • Gar the pilot
          Dumb Donkey butt moment,.. I don't remember the jam code. will have to go by and recheck on that. Thanks for the reminder,..KISS. and get the code.
            • 23010
            There were two different document feeders available on this model.
            DADF-A1 and DADF-B1. That also would be good to know. =^..^=
            • Gar the pilot
              data plate on feeder says F24 3002 SN ZNE55165 and FB4-7019. I will look again, Hopefully today. What else should I look for as to which one this is? Canons are about 5% of what I do so a little lost sometimes on these. Thnaks for the help
              • teckat
                • 16083
                this the B1 Plate===SN ZSxxxxxx
                DADF-B1
                AB SIZE F25 - 1601 = ZSB00001 -
                A/INCH SIZE F25 - 1611 = ZSC00001 -
                A SIZE F25 - 1621 = ZSD00001 -
                AB/INCH SIZE F25 - 1631 = ZSE00001 -
                ZNxxxxxx may be a A1
                  • 23010
                  I have 27 records on DADF-A1, and 22 records on DADF-B1.
                  It's a DADF-A1.
                  SN range: ZNE00001
                  SN range: ZNG00001
                  • Canuck
                    Tech Specialist
                    • 1713
                    Jam Codes
                    I have seen white lever flip over like Tek said..
                    • Gar the pilot
                      I wasn't able to find the jam code for this. It just shows a picture of where it thinks the jam is on the display with no code that I could find. I only have Intravia's to go on. Hard to catch up with client as they are out a lot, makes follow-ups slow.
                      Thanks.
                        • 23010
                        Sorry Gar. My database has no pictures. All the records refer to jam codes viewable from service mode. It's been over 10 years since I've seen one of these. Any visual memory is now long gone. =^..^=
                        • Gar the pilot
                          I will look again for the codes next time I catch them in. Intravia's gets me most of the way through many Non-Mita's, but it does hang me out to dry sometimes. It's been almost 20 years ago that I worked at a duel line company with Canon as the second line. Right now we are Mita/Samsung, but will work on almost anything,..small town ( 15 K) and local county = 100K. Happy Thanksgiving!
                          • Gar the pilot
                            I followes the test that "Teckat" listed for me all okay there. It cought me off gaurd when the client was in so I forgot to bring the Intravia's guide in to get jam codes,bummer. Paper stops about 1" out of the exit so I guessing an exit sensor/actuator arm problem. Intravia's list I/O operation check but dosen't list what each bit is so no-joy there. anyone have the I/O check list for the adf sensors??
                            Thanks Gar
                            • teckat
                              • 16083
                              Thanks Gar
                              see attach
