Send problem in Image runner advance
  • mramlawi
    • Jul 2011
    • 838
    hello , to all
    i have a problem in ir advance when i want to use the send to computer i couldn't see the work group i wonder why this happen im sure its not a copier problem but will be thankful if any one can help ,this is always happen in win7 and above i disable the firewall and the antivirus also i turn on the network settings and still the work group not appearing .
    Distinguished road makes you jewel in rough
  • ernesto
    • Oct 2011
    • 430
    Re: Send problem in Image runner advance
    Originally posted by mramlawi
    hello , to all
    hi,
    You can try to set up the address book manually, putting the ip of the pc where you want to scan
    All the best
    • pinkia
      • May 2009
      • 19
      hello , to all
      Dear Friend,
      might be problem with domain name, you have feed it in machine. or you can directly add address through RUI.
      Hope this will help you.
      • copier tech
        • 8164
        Turn on DHCP, reboot to let the machine pull all the network settings, then try to browse the workgroup again
        • mramlawi
          • Jul 2011
          • 838
          Thank u if found somthing inside settings will check it lattar on share you thanks
