IR 330S thumping sound in vertical transport
  • lakeman78701
    • May 2008
    • 44
    I havent seen this machine in a long while and it is making a thumping sound in the vertical transport...the tires etc need replacing, but is there a clutch that I can clean or do I just replace the motors to make the thump go away....yes it does jam there, and now that it thumps more frequently...
    • 23009
    You've probably got a damaged sector gear or ratchet. For details see this post: http://www.copytechnet.com/forums/ca...lift-mech.html
    The feed unit is exactly the same. =^..^=
    • lakeman78701
      • May 2008
      • 44
      thanks blackcat...I have had the same problem with the old 6030...just not working on canon for a while makes you forget the usual stuff....but it is kinda nice to have it happen on a charge call! $$$$$ oh boy!
        • 23009
        You've got two choices:
        Order the feed unit & 1 hr labor, and make your profit on the parts,
        or order the individual parts & 2.5 hrs labor & make your profit on the labor. It works out about the same either way. =^..^=
        • lakeman78701
          • May 2008
          • 44
          you were exactly right blackcat...it was the gear...thanks again
          • Oze
            Ricoh Fanboy
            • Jul 2008
            • 1663
            Thanx for posting back that it was fixed
