Canon iRC3100 Weird Fault
  • callmeozzy@hotmail.com
    I have an iRC3100 with the following issues:
    It copies from the glass without a problem.
    If i try and copy from the Document Feeder, the machine picks up a sheet of paper, takes it to just before the registraion roller and sits there with the machine displaying "copying". A long while later the machine displays a jam. Exactly the same thing happens when printing from a PC.
    There are no error codes or alarm codes at all.
    If i try to cancel the job the machine sits there displaying "cancelling" but nothing happens.
    Any clues ? This one's got me scratching my head
    Cheers Andy
  • Oze
    Ricoh Fanboy
    • 1663
    I'll look on Canon techbase tomorrow and post up during the day if I find anything.
      • 23007
      Having no specific experience with this model, but lots of experience on Canon, I would say this sounds like the exposure lamp is not reaching the desired brightness. In this order I would check:
      1) for any codes stored but not displayed (specifically E220),
      2) for any blackening of the exposure lamp (I'm making the assumption that this is fluorescent)
      3) for any arcing of the lamp terminals
      4) replace lamp
      5) replace inverter
      I've seen these exact symptoms on a wide variety of different Canon machines. As part of the warm-up many MFP's check lamp intensity, even if no scanning is required. =^..^=
        [quote=blackcat4866;41103]Having no specific experience with this model, but lots of experience on Canon, I would say this sounds like the exposure lamp is not reaching the desired brightness. In this order I would check:
        4) replace lamp
        5) replace inverter
        I've seen these exact symptoms on a wide variety of different Canon machines. As part of the warm-up many MFP's check lamp intensity, even if no scanning is required. =^..^=[/quote
        Thanks for the reply. Thats sounds quite logical but i can still copy from the glass without a problem. I am going to reload the System software on Monday. I recalled having a similar problem on an iR2200 some time ago. I will advise if it sorts out the problem,
        Cheers Andy
        • Oze
          Ricoh Fanboy
          • 1663
          Does the machine have a finisher Andy?
          • Oze
            Ricoh Fanboy
            • 1663
            Andy,
            Unplug all the connectors on the Image Reader pcb and plug them back in.
            We had an iRC4080 doing the exact same fault today in the showroom.
            Different DADF but you never know.
            • kwazimoto
              • Jan 2007
              • 199
              i know this might sould wierd but does this happen when feeding letter R or legal paper thru the Df??? if so might try setting DF size sensors feeder function...
              • kwazimoto
                • Jan 2007
                • 199
                ae you getting jam code 0b00 or ob01 one fix is do a copier>function>system>chk-type 1 thru 9 and copier>function>system>hd clear took care of the problem...
                  Oze and Kwazimoto....i will try each of the things you have suggested. Thanks for your help. I will let you know how i go,
                  Cheers Andy
                  • Oze
                    Ricoh Fanboy
                    • 1663
                    Kwazi's answer but in detail:
                    Product :
                    imageRUNNER C3100 / C3170 Title : The imageRUNNER will copy but will not print. Problem :
                    Solution :
                    The imageRUNNER will copy fine but when attempting to print the paper will stop at the Registration Roller and the machine will cycle continuously instead of printing. This issue can be caused if the there is bad or corrupt data on the hard drive. To remove the bad or corrupt data, Hard Drive Clears should be performed.
                    To perform the HD Clears go into service mode COPIER>FUNCTION>SYSTEM
                    Select CHK-TYPE and set it to 1 and press ok.
                    Then select HD-CLEAR and press ok.
                    Select CHK-TYPE and set it to 2 and press ok.
                    Select CHK-TYPE and set it to 3 and press ok.
                    Select CHK-TYPE and set it to 4 and press ok.
                    After completing this procedure, power cycle the copier and reenter any user settings.
                      Guys, i solved the problem with a new Hard Drive. The giveaway was that i was able to copy from the glass which scans to RAM whereas a print job or copying from the feeder uses the Hard Drive! Thanks for all your input,
                      Cheers Andy
