c5051
  • CrapAimer
    • 296
    [Error Code] c5051
    Hi
    Ricoh dealer here, customer has asked me to look at a c5051 with an error code E000407-0002. Think it has something to do with the document feeder
    Any help appreciated
    George
  • Rvale
    • 83
    Re: c5051
    ADF all the way.
    E407 0002 05 Title Tray Lifter Motor error
    Description Paper Face Detection Sensor when Lifter is being lifted does
    not become ON within specified time.
    Remedy 1. Check that after Lifter is lifted fully, it is located in the
    correct position. (Check the engagement with the Gear.)
    2. Check the Tray Lifter Motor, and also check whether
    shifting operation is performed normally.
    3. Check the connection between Paper Face Detection
    Sensor and DF Driver PCB, and check that the Cable is not
    open-circuit.
    4. Replace the DF Driver PCB.
    5. Replace the Tray Lifter Motor.
    • copier tech
      • 8192
      Re: c5051
      Or most likely customer has dropped a pen etc into the feeder so it cant lift!
