CANON IRC2380 cyan is more fade
  • Orion2010
    • Jun 2015
    • 176
    hello to all,i have canon ir c2380, a client says 3 day before replace all drum, in other service, but cyan is lined and more fade !!! any idea ?? IMG_0803.JPGIMG_0804.JPGIMG_0805.JPG
  • teckat
    • 16083
    Re: CANON IRC2380 cyan is more fade
    Originally posted by Orion2010
    hello to all,i have canon ir c2380, a client says 3 day before replace all drum, in other service, but cyan is lined and more fade !!! any idea ?? [ATTACH=CONFIG]32352[/ATTACH][ATTACH=CONFIG]32353[/ATTACH][ATTACH=CONFIG]32354[/ATTACH]
    Issue for CYAN was before drum replacement, or after replacement._?
    Using Canon OEM PARTS _?
    • Orion2010
      • Jun 2015
      • 176
      after replacement
      • ernesto
        • Oct 2011
        • 430
        after replacement
        I think this is a coincidence, it must be cyan drum does not work right.
        • copier tech
          • 8100
          Did you rebuild the cyan drum? or fit a complete new genuine Canon unit?
          • Orion2010
            • Jun 2015
            • 176
            compatibel drum
            • copier tech
              • 8100
              No further questions your honour........
              • dan7777
                • Dec 2012
                • 680
                compatibel drum
                I had a bad canon black drum on printer. Confirmed by putting old drum back in. Lines moved.
                • Orion2010
                  • Jun 2015
                  • 176
                  Why the cyan now seems magenta ???
                  • zoraldinho
                    teacher-guide-expert-guru
                    • Mar 2008
                    • 4999
                    Black drum??I thought you have cian problem?!
                    • zoraldinho
                      • Mar 2008
                      • 4999
                      Because there is no cian at all!
                      • teckat
                        • 16083
                        One word= ITB
                        =:O
                        • Orion2010
                          • Jun 2015
                          • 176
                          i print and copy only cian but it seems magenta, i make calibration but nothing !!!
                          sorry for my bad english
                          • JPiek
                            • Oct 2014
                            • 435
                            To get things clear ;
                            1 customer complains about Cyan
                            2 All drums are replaced with NON OEM Drums
                            3 Cyan gets ever worse, then looks like magenta and not like Cyan ?
                            a: Print a PG5 of eacht color and check.
                            b: Open printer and have a look at all the drums, specialy Cyan and magenta
                            - Toner spill ?
                            - Lines in drums ?
                            Try putting back the old drums if you still have them
                            c: have a look at the ITB like allready suggested.
                            Johan
                            • tech28
                              • Jun 2013
                              • 434
                              Run a piece of paper in the underside of cartridge, in between the drum and developer, run the paper back and forth where the line/lines are, insert drum and see if there is a difference. Good Luck. Lot of times the developer brush gets obstructed causing the light areas/lines.
