Canon IR 3100N E000020-0081
  • A2600
    • Apr 2016
    • 13
    #16
    Re: Canon IR 3100N E000020-0081
    every time I do a power cycle I see the P-Sens-P go up
    0
    44
    94
    122
    134
    but as soon as I hit 134
    Whack
    back to 0
    • copier tech
      • 8132
      #17
      Are you sure you are cleaning the correct sensor? you can only see the small flat part of the sensor, like I say it sits just above the drum.
      If you are sure this is clean then the sensor could be faulty.
      This is from the service manual "P-SENS-P Use it to check the measurement (for P wave component) of the soiling
      of the window of the patch image sensor. The value effective when the
      machine executes patch image detection operation after the main power
      switch is turned on is indicated.
      (range of indications: 0 to 1023)In the case of 255 or lower, the indication
      will be E020-0081.
      Optimum:400 to 600"
      • A2600
        • Apr 2016
        • 13
        #18
        I believe its faulty as I think is as clean as its ever going to get.
        I looked it up and the price range is between 40 and 60 dollars
        • copier tech
          • 8132
          #19
          Yes its only a cheap part, but it is not easy to get to especially if you have an internal finisher.
