Canon IR 3100N E000020-0081
  • A2600
    • Apr 2016
    • 13
    [Error Code] Canon IR 3100N E000020-0081
    Hi guys, sorry to barge in here and have my first post be asking for help, I have been a long time lurker as you guys know these 3100 are a pain in the whazoo.
    I have had the machine since 2008, no problems what so ever in 2013 I had the same drum replaced by a tech due to the same 0020-0081 code.
    But now in 2016 I'm thinking the sensor might be dirty, checked the copy menu and a P-SENS-P of 253
    Would I need a new drum again or can I go in there and clean the sensor?
    If so how do I get access to the sensor to clean it?
    Thanks Guys
    Bryan
    Lurker Extraodinare
  • A2600
    • Apr 2016
    • 13
    Re: Canon IR 3100N E000020-0081
    Drum life is 40%
    • A2600
      • Apr 2016
      • 13
      My drum has toner dust all over the upper edge, how do I clean the drum?
      • A2600
        • Apr 2016
        • 13
        Cleaned the unit but nothing yet
        P-SENS-P is now at 137
        DENS Y-7.93
        DENS M-12.50
        DENS C-13.14
        DENS K-02.49
        Y- 514
        M- 513
        C- 514
        • A2600
          • Apr 2016
          • 13
          Still looking for help, please
            • 8132
            All you need to do is clean that patch sensor, simply remove the drum, use a flashlight you'll see the sensor above the drum about halfway in, use a damp cloth, not dry.
            Then then check the P-SENS again when clean the sensor should read over 500.
            You may find it comes back, but simply clean it again, this is normal on this old machine!
            Keep an eye on the P-SENS reading try to keep it about 500 the machine will run much better.
            • A2600
              • Apr 2016
              • 13
              is there a way to remove the sensor to clean it outside the unit?
                • 8132
                Theres no need all you need to do is remove the drum, it can easily be reached just a quick wipe is all thats needed.
                • A2600
                  • Apr 2016
                  • 13
                  I tried that last week but the P-SENS-P dropped, but I will try again
                  • A2600
                    • Apr 2016
                    • 13
                    could I use rubbing alcohol to clean the sensor
                    • jrgf67
                      • Feb 2010
                      • 37
                      Saludos. Debes cambiar el sensor de parche referencia FH7-7629-020.
                      Greetings. You must change the reference sensor patch FH7-7629-020
                      • A2600
                        • Apr 2016
                        • 13
                        the more I clean the sensor the lower the P-Sens-P
                        Yesturday 132
                        Today 131
                        is there anything else that needs be cleaned aside from the little black window?
                        • A2600
                          • Apr 2016
                          • 13
                          I have hit rock bottom, my P-Sens-P is 0
                            • 8132
                            It will say zero after you have cleaned it. Next time the machine does a gradation or comes out of sleep etc check p-sens again it will be over 500😉
                            • A2600
                              • Apr 2016
                              • 13
                              can I force a gradiation? because as it come out from sleep
                              I now have 0 again
