IRAC2030 E733-005 + other errors
  • copier tech
    • 8195
    [Error Code] IRAC2030 E733-005 + other errors
    Hi all, bit stuck on this one, been to an IRAC2030 that throws various E7xx errors, i'veseen this a few times on the older irc2380 series but not on the IRAC series.
    I removed all the Ram & dims etc & all theconnections to the DC controller etc, re-assembled but same error. Occasionallythe machine will come to ready & allow me to print etc but after 5 mins orso it will error again.
    Am I looking at DC controller, Ram, HDD??
  • teckat
    • 16083
    Re: IRAC2030 E733-005 + other errors
    Friend says his experience is with that
    Flexible Cable between the DC Controller PCB and the Main Controller PCB 2.
    • apoxi
      • Nov 2015
      • 45
      Do you resolve this problem?
      • copier tech
        • 8195
        Yes, my collegue went back with the ribbon cables as mentioned by teckat he also replaced the dc controller, however I suspect it was only the cables causing the issues
        • raptaqua
          • Jan 2015
          • 15
          Also the low voltage power supply (FM3-8179) can cause this error.
          if that's broken it can give you 3-5 different error codes.
