Canon iR ADV C5051 Set Limit Colour
  • darknet93
    • Nov 2015
    • 89
    Hi, how do i set Limit colour setting for iR ADV C5051 ?
    means the step by step for Colour only & for both (B&W and Colour)
    Thank You
  • MunsterTech
    • Sep 2014
    • 381
    Re: Canon iR ADV C5051 Set Limit Colour
    isnt that thru the smart head and then pin codes where you can set limits? is that what you mean?
    • charm5496
      • 2387
      Question :
      How do you Prevent Color Copies using Department ID?
      Answer :
      To prevent Color copies from being made using Department id, follow these instructions.
      1) Select [Additional Function].
      2) Select [System Settings].
      3) Select [Department ID Management].
      4) Select [ON].
      5) Select [Register Dept.ID/Password].
      6) Select [register].
      7) Enter a Department ID number with a password.
      8) Select [Turn Limits ON/OFF and Set Page Limit].
      9) Select [Color Copy Limit] and turn [ON] and leave counter to 00000.
      10) Press [OK]
      If you try to make a copy the copier will not permit you. You will get an error message: [Reached counter Limit. The printing/reserved jobs may be stopped. Check the print logs].
      For imageRUNNER ADVANCE Models
      1) Select [Settings/Registration].
      2) Select Login
      3) Enter The System Mgr and System Pin and press [Login].
      4) Select [Management Settings]
      5) Select [User Management].
      6) Select [Department ID Management].
      7) Follow directions from step 4 above
      • darknet93
        • Nov 2015
        • 89
        Originally posted by charm5496
        Question :
        Answer :
        4) Select [ON].
        10) Press [OK]
        2) Select Login
        WOW Thanks its help me a lot. now if i want to make no need to key in ID for Black&White only for colour need ID. how do i set it ?
        • copier tech
          • 8172
          & what about restricting print too, is there a colour PDF available for this?
          • charm5496
            • 2387
            you can change those settings under settings/registration.
            allow B/W copies and prints or leave everything locked down. However you choose to set it up.
