Copy and Send Icons Missing. Imagerunner Advance 6065
  • mts777
    • 20
    I had a hard drive crash on an Imagerunner Advance 6065. Installed the hard drive and system software, now I have several icons missing including Copy and Send. What did I do wrong and what I can do to fix it?
  • dan7777
    • Dec 2012
    • 680
    Re: Copy and Send Icons Missing. Imagerunner Advance 6065
    Thanks[ATTACH=CONFIG]33269[/ATTACH]
    Push the show all button to see if they are there. If they are you have to log in and push the box it right upper corner and go to the menu buttons to put them back on the main screen.
    • roho
      • Mar 2009
      • 844
      Sign in as admin "registration/additional functions", then the upper right icon should be lit on the home screen. Activate that to open the menu for configuring the home screen.
      • aco.bk
        • Sep 2012
        • 130
        • mts777
          • 20
          Tried both suggestions. When I tried to add from the menu, the copy icon not an option to add. Tried changed the value in service and got and e732 error. The feeder is recognized, it lights up when I put a document in the feeder. I just can't copy. Thanks for the suggestions.
          • mts777
            • 20
            I have a theory of what went wrong. I only have V2 software for this model. Without having v1 I think I am missing the software that adds those icons. When I do a compare P-PRINTs of before and after, I am missing COPY-AP, SEND-AP, BOX-AP. That being said, does anyone have any version 1 firmware for the 6065? Thanks.
            • aco.bk
              • Sep 2012
              • 130
              What happened when You try flash system through updater on machine?
              • copier tech
                • 8172
                Yes, get the machine on the network & set up correctly then update the system software vid CDS & choose over write all
                • teckat
                  • 16083
                  Format HDD & Re-Load FIRMWARE
                  Are the settings below > shown as Available under service mode in Level 2...Copier > Option > DSPLY SW>
                  UI-COPY
                  UI-SEND
                  UI-FAX
                  UI-PRINT
                  • mts777
                    • 20
                    UI-COPY
                    UI-SEND
                    UI-FAX
                    UI-PRINT
                    Yes, they are there, but if I try to change the value, it says "NG"
                    • mts777
                      • 20
                      I don't see an option to overwrite all.
                      • mts777
                        • 20
                        Ok. I found the problem. I didn't have copy, send and box registered in sst. Not sure how that happened, but I registered it and loaded it via sst and I now can copy, send etc... Thanks for your help.
                        Matt
                        • teckat
                          • 16083
                          Matt
                          • anth0
                            • Jun 2023
                            • 3
                            I've just had the case on a DXC 5840i, Scan and send function disappeared after having done some testing with the (new) device.
                            The UI Send was just deactivated (put to 0) , i just did Copier > Option > DSPLY-SW > Level 2 > UI Send from 0 to 1, and restart the device
                            • ADV COPIER
                              Pemain
                              • Nov 2022
                              • 257
                              Let's Drink our Coffee
                              WhatsApp +62895325228383
