IR 3380i streaks
  • Raymann
    • Apr 2015
    • 73
    IR 3380i streaks
    I suspect developer/doctor blade clogged.. what do you think? black is ok but the other colors have similar lines. from prints or copy's. I have cleaned the laser optics did the normal user adjustments for exposure. File0001.PDF
  • charm5496
    • 2387
    Re: IR 3380i streaks
    these models are prone to clumping in the drum unit. You can take it apart and clean it up normally
    • Burdy500
      • May 2016
      • 44
      did you replaced color drums already?
      Verstuurd vanaf mijn GT-I9505 met Tapatalk
      • JPiek
        • Oct 2014
        • 435
        Right, do a PG5 on all drums, if the streaks are only on color, probably a drum problem. Compare PG5 with the removed drums, lines on the roll of the drums ?
        Hey, another dutch fellow here
        Johan
        • Burdy500
          • May 2016
          • 44
          ☺ or testprint 10
          almost sure drum problem
          • JPiek
            • Oct 2014
            • 435
            I prefer 4x a PG5 over a PG10, more surface and i often see smears or white spots I wouldn't ony a PG10.
            I use PG10 as quick check if there are lines over the whole length...
            2x PG5 on A3 is nice to check ITB surface
            Johan
            • Raymann
              • Apr 2015
              • 73
              pg5? I am not canon certified. Old school certified. any special tricks to disassembly or just go for it?
              • JPiek
                • Oct 2014
                • 435
                Internal test prints :
                Press "Maintenance" button (the head with an *) press 2&8 simultaneously, press "Maintenance" again.
                Press copier-> test> PG
                Select "type" and enter 5 (or 10 )
                Select color Y/M/C K (Black)
                set one of them to "1" , the others to "0"
                Press the startbutton.
                Do this for eacht color.
                PG5 you get a whole page in the selected color (set to 1)
                Or select all colors and select Pg10, you get 1 page with all colors next to each other.
                Now look at the testprint for lines in any of the colors... (or post the here )
                Johan
                • Burdy500
                  • May 2016
                  • 44
                  Just replace the colordrums & autogradation 》 ready
                  • copier tech
                    • 8164
                    You don't disassemble the drum units on this model, simply replace the complete dev/dev unit as one!
                    • Jake2o
                      • Dec 2007
                      • 325
                      Yes that is more than likely the developer clogging up.
                      I've just replaced the Developer in all 4 colours for a 3380i its simpe enough once you've cracked open the casing. It is glued on so needs some prying to get it open.
                      There is very rarely anything wrong with the drums on these machines.
                      More worryingly though after the 2 white lines we are all looking at there appears to be a thumb or finger print in the black tint / solid towards the bottom of the pdf.
                      • charm5496
                        • 2387
                        yes, you can just throw them out and install new ones, but when you have a good drum unit with just some debris on the doctor blade, you take it apart and clean it.
                        • Raymann
                          • Apr 2015
                          • 73
                          I have printed the separate colors. My scaner is nor color can't post. Thanks for the procedure I'm sure I will use it.
                          • tech28
                            • Jun 2013
                            • 434
                            You could try this, whenever you get line/lines, I have(sometimes successful) get a piece of paper and turn the drum/DV unit on its side and slide the paper into the slit between the drum and developer, where the area of the line is at, slide the paper back and forth, have many a times taken care of that void area where that particular color has light streaks, then turn mag roller(with needle nose) back and forth a couple times, then try it. Good Luck.(that has saved me lots)
