Canon iR3245 - Touch Panel very slow
  • luis1984bol
    • Nov 2011
    • 155
    [Misc] Canon iR3245 - Touch Panel very slow
    Hello friends:
    I have an iR3245, it is configured to copy/print and email/smb scan. When I try to scan to folder, the touch panel does not respond normally, it is very slow.
    I already change the firmware to 48.02 version, clean de HDD and memories too. The machine has the security HDD erase data kit.
    Do you have any idea about this issue?
    Thanks!!!!...
  • dan7777
    • Dec 2012
    • 680
    Re: Canon iR3245 - Touch Panel very slow
    Originally posted by luis1984bol
    Hello friends:
    Thanks!!!!...
    If it does not respond replace the touch screen. You can calibrate it in service mode. On the newer advance canons I replace the CPU board under the control panel.
    • Burdy500
      • May 2016
      • 44
      you could try reinstall firmware, otherwise replace CPU or complete control panel
      • luis1984bol
        • Nov 2011
        • 155
        Hello my friends:
        I have already replace the touch panel, format de HDD and reinstall the firmware too.
        Which option in service mode?
        Thanks!!
        • Burdy500
          • May 2016
          • 44
          is it also slow without network connection? maybe a issue on your network
          otherwise maincontrolller
          • luis1984bol
            • Nov 2011
            • 155
            • tartzu
              • Oct 2014
              • 13
              Did you get rid of that touch screen problem?
              • copier tech
                • 8171
