ir 4570 error e100
  • ernesto
    • Oct 2011
    • 430
    ir 4570 error e100
    Hi,
    I have an intermittent error 100,it has been changed laser unit, dce controller and removed laser shutter...
    Does anyone know what can be the problem.....?
  • Helpdeskforum
    • 28
    Re: ir 4570 error e100
    replace dc controller did you do?
    very old machine ...
    maybe it's a bad contact from the metal registration roller to the little earth-spring at the side of this roller: clean the area there and some electro spray will take away this error
      • 23008
      I've always used conductive grease on that registration contact. or you'll get rust and screeching. I have not had any negative results from using the conductive grease. =^..^=
      • ernesto
        • Oct 2011
        • 430
        does it mean that small metal ?
        • Helpdeskforum
          • 28
          yep!
