IR 4570 - Jamming problems
  • SCREWTAPE
    Originally posted by Karsten
    Just to get everybody more confused
    I just checked with Canon again to be sure and it turns out that both Screwtape and I are correct. Both part#s FM2-0131/0132 AND FM3-1296/1297 are correct. They all still exist and EITHER can be used.
    Canon always does this. Take care Karsten.
    • redzventures
      Service Tech
      • May 2009
      • 45
      You guys are good!
      You guys are good. The pressure pads on the lower right door need to be replaced by something firm. I use either the rubber from a tyre/roller cut to size (works great) or the hard back of those impregnated shoe polish sponges - also works great cut to size. The Canon modification pressure strip is too weak.
      Good Luck
      www.canonservicemanual.com
      • Joe Karanja
        • Jun 2009
        • 12
        Go to Service mode(*2$8 *) copier-Display-Jam-touch your immediate jam.it will tell you the jam type and the sensor number.
        • Vista Tech
          • 116
          #19
          Thanks for all the help guys.I fixed this machine a while ago, had NO idea that in order to change the vertical path rollers I needed to take apart the entire side of the machine. It was an experience for sure. Couldn't have done it without you guys.
