Canon IRC2220 HDD
  • hsrmms
    • Dec 2014
    • 69
    [Error Code] Canon IRC2220 HDD
    Hello everybody....
    In Canon IRC 2220 gives error code 602-001 problem with HDD I had replaced but still not working give me same error code.
    When machine start up give error 602-001 pressed *28* will give in left upper corner 4 option [1] check [2] HD Check [3] HD Clear [4] HD operational disable.
    Could you advice me how to install new HDD and which option should i use.
    Regards.
  • kuby
    • Oct 2007
    • 1408
    Re: Canon IRC2220 HDD
    First you have to have a compatible hard drive (not just any hard drive will work)
    You need the Canon Support Tool and you need the Firmware for that model.
    If you have not already you need to register the firmware with the Support Tool. Start the Support Tool, attach the cables to the copier, start the copier while pressing 2+8 till in Upload mode. Select the copier you want to upload the firmware to and go from there.
    • hsrmms
      • Dec 2014
      • 69
      I had compatible HDD (FK4-1550-000) Could you advice me how to install HDD (Hardware & Software).
      Regards.
      • copier tech
        • 8169
        It is not a simple process on this old Canon.
        Have you tried to recover the old HHD?
        Fit the old HDD back in the machine, then power on the machine while holding down buttons 1&9 this will run a scan disk type of repair, you should see some white boxes on the screen, it can take about 60 mins to complete. When the screen shows "download standby" the process has finished. Power off & on the machine & see if it will boot.
        • hsrmms
          • Dec 2014
          • 69
          The old HDD make clicking sound so i think it is damaged.
          Regards.
          • copier tech
            • 8169
            Ah yes it will be dead!
            • teckat
              • 16083
              Regards.
              You mean a iR2220 (the only C2220 is an advanced model)
              1. imageRUNNER Service Support Tool ( SST)---Needed
              2. iR2220 Firmware---Needed
              3. New HDD must be formatted inside printer, using SST connected to printer/ with printers firmware registered into SST/ & using the 2220 format file firmware.
              imageRUNNER Service Support Tool Connectivity-----------------for your model
              CROSSOVER CABLE
              NORMAL POWER ON MODE
              [Customers IP: 192.19.1.20 - Laptop: 192.19.1.21]
              Connect in reference to customers IP Address
              "CANNOT" PERFORM HD-FORMAT
              CROSSOVER CABLE
              FIXED IP MODE
              [Set Laptop for 172.16.1.101]
              CROSSOVER CABLE
              SAFE MODE
              [HOLD DOWN 2 & 8, POWER "ON" Machine]
              PERFORMING HD-FORMAT
              USB TO PARALLEL [FY9-4154-000]
              [Nethawk Driver Needed]
              SERVICE MODE
              [SERVICE MODE>COPIER>FUNCTION>SYSTEM]
              SERVICE MODE
              [* 2 & 8 *]
              • hsrmms
                • Dec 2014
                • 69
                CROSSOVER CABLE
                CROSSOVER CABLE
                FIXED IP MODE
                CROSSOVER CABLE
                SAFE MODE
                SERVICE MODE
                SERVICE MODE
                [* 2 & 8 *]
                Copier model is Canon iR-ADV C2220
                • hsrmms
                  • Dec 2014
                  • 69
                  CROSSOVER CABLE
                  CROSSOVER CABLE
                  FIXED IP MODE
                  CROSSOVER CABLE
                  SAFE MODE
                  SERVICE MODE
                  SERVICE MODE
                  [* 2 & 8 *]
                  Could you advice me what to do after installing new HDD (FK4-1550-000). THANKS FOR YOUR HELP
                  • kuby
                    • Oct 2007
                    • 1408
                    You need to format it using the Canon System Support Tool like teckat's instructions.
                    • teckat
                      • 16083
                      U NEED TO FORMAT HDD ---
                      then load registered firmware
                      Content Delivery System: (CDS)
                      CDS is a service infrastructure where the system software is pushed to the imageRUNNER
                      ADVANCE by ways of the internet.
                      SERVICE MODE > UPDATER > UPDATE FIRMWARE > CONFIRM APPLICABLE FIRMWARE
                      Service Support Tool: (Start Assist Mode)USB Flash Drive:
                      Flashing the System Software by use of a USB Flash Drive is supported.
                      SERVICE MODE > COPIER > FUNCTION > SYSTEM > DOWNLOAD
                      • hsrmms
                        • Dec 2014
                        • 69
                        Thanks for your replay....
                        I have another Canon iR Adv c2220i can I extract the Firmware from that copier and load it to the same model??
                        Regards.
                        • copier tech
                          • 8169
                          No, however you could use the good hdd in your dead 2220L providing the doner machine is also an L model
                          • hsrmms
                            • Dec 2014
                            • 69
                            Can I make image of the working HDD and load it to new HDD??
                            Regards.
                            • copier tech
                              • 8169
                              Yes I have done this a few times I used Acronis.
