check your document
  • tsmitherman
    • Aug 2016
    • 4
    [Dead] check your document
    canon ir5055 document feeder dadf-s1 "check your document" message apears on screen soon as i hit start
    • 2621
    Re: check your document
    Does the green light on the feeder come on?
    Have you tried a sens-init
    copier > feeder > function > sens-init
    • dan7777
      • Dec 2012
      • 680
      I have had that on the advance series. It is always a flag (that actuates sensor) out of place (usually right after the feed roller). Don't know about this series but something to check. Luckily I don't have but a couple of these models in the field.
      • charm5496
        • 2387
        see that attached file, this is a fairly common issue with these DADF's if they are in a high use area
        • tsmitherman
          • Aug 2016
          • 4
          the green light does come on. have tried sens init no luck
          • tsmitherman
            • Aug 2016
            • 4
            I have replaced all the sensors still check your document after pressing start.
            • tsmitherman
              • Aug 2016
              • 4
              Originally posted by charm5496
              [ATTACH=CONFIG]34057[/ATTACH]
              i seen this on e-support i pull the fan and traced the wires. i didnt find anything that looked bad, and the fan works
