Are the yellow lines supposed to be there along the bottom of the image? I think maybe not. It's looks a lot like a repetitive defect. =^..^=
I'm with Zoraldinho, looks like smudgeing... Can you whipe off or smear the toner when it does this ?
If it was the drum i'd expect this to be on every printout...
I would remove ITB--- then remove bottom metal plates----clean underside---inspect if either plate has a slight bend ??? any slight bend interferes with image on belt--especially on trailing edge of long side stock ( that stock has a tendency to lift up a bit on separation -
