output
  • ps22sp
    • Aug 2014
    • 83
    output
    canon c3200 output every ten copies has one or two see the bottom
    drum need to be replace?magenta?
    • 16083
    Re: output
    do lines move from position shown ??
    • ps22sp
      • Aug 2014
      • 83
      Re: output
      lines are original design.
      the problem is words
      kissena boulvard
      flushing ny 11355
      those characters
        • 16083
        Re: output
        kissena boulvard
        flushing ny 11355
        those characters
        What type of paper stock being used_?
        Go into the Service mode COPIER>OPTION LEVEL 2>BODY and adjust FX-SPD and EX-PS-SP and set to +2.
        FX-SPD adjusts the fixing roller speed and EX-PS-SP adjusts the Paper Delivery Vertical Path Motor speed.
        NOTE: These values can be adjusted between -2 and +2. Factory specification is at 0
          • 23008
          Re: output
          Are the yellow lines supposed to be there along the bottom of the image? I think maybe not. It's looks a lot like a repetitive defect. =^..^=
          • zoraldinho
            teacher-guide-expert-guru
            • Mar 2008
            • 5013
            Re: output
            I believe it's fixing problem.
            • JPiek
              • Oct 2014
              • 435
              Re: output
              I'm with Zoraldinho, looks like smudgeing... Can you whipe off or smear the toner when it does this ?
              If it was the drum i'd expect this to be on every printout...
              Johan
                • 16083
                Re: output
                poster needs to indicate if issue is only on trailing edge of copies ???
                & type of paper stock ???
                could just be stock issue
                if this is Heave Stock-----------------it may cause too great a paper arch that is created between the 2nd Transfer Roller and the Fixing Assembly .
                Increase the fixing speed for heavy media with service mode level 2 COPIER>OPTION>BODY>FX-SPEED2 (the larger the value the faster the fixing speed).
                I believe poster means magenta text smear/blast on bottom on image ?????????
                I would remove ITB--- then remove bottom metal plates----clean underside---inspect if either plate has a slight bend ??? any slight bend interferes with image on belt--especially on trailing edge of long side stock ( that stock has a tendency to lift up a bit on separation -
