Hi
facing uneven density on solid colors
* while printing some solid colors uneven density of color happening in the output
* top rear edge of image having this issue( that is the top rear edge is darker than the rest of the image)
action taken
*to confirm the issue ,printed the pg 5 ,only its happening with magenta and other colors are ok
*cleaned the dv unit sleeves as manually and service mode 2 (dvs-clnx)
*and replaced all the colors drums (life expired )
*but the problem was there before and after replacing of the drum
kindly have look on the attachment [ATTACH]34299[/ATTACH]
action taken
