Image press c800 uneven quality
  • gksapple
    • Apr 2014
    • 116
    [CQ] Image press c800 uneven quality
    Hi
    facing uneven density on solid colors
    * while printing some solid colors uneven density of color happening in the output
    * top rear edge of image having this issue( that is the top rear edge is darker than the rest of the image)
    action taken
    *to confirm the issue ,printed the pg 5 ,only its happening with magenta and other colors are ok
    *cleaned the dv unit sleeves as manually and service mode 2 (dvs-clnx)
    *and replaced all the colors drums (life expired )
    *but the problem was there before and after replacing of the drum
    kindly have look on the attachment [ATTACH]34299[/ATTACH]
  • raptaqua
    • Jan 2015
    • 15
    Re: Image press c800 uneven quality
    have you updated the firmware?
    have you tried init + stir ?
    does it come to every paper type? and what is that paper that you are using?
    • roho
      • Mar 2009
      • 844
      I'd check the mag dev assembly itself first, see if there's a good coating of toner on the dev next since you've changed the drums. I run pg 5's at 55, and 128 density usually, but a 255 setting can be good to determine "tiger striping", where the dev becomes depleted on one side, run a few 11x17.
