Advc5051 remove paper from output tray erro
  • madas
    • Aug 2008
    • 313
    Hi guys
    Not seen this myself at the customers but they tell me that they get the "remove paper from the output tray" error and have to switch machine off/on to clear it?
    This machine has an internal finisher, all seems ok sensors move freely at the tray and exit.
    Firmware up to date and the finsiher has had a new pcb for a different fault a month or so ago.
    No jam just the message.
    Any ideas as I am not that familiar with the finishers?
    Cheers
    Les
    • 8132
    Re: Advc5051 remove paper from output tray erro
    This is a service mode option on by default after you replaced the board I guess it switched back! It tells the customer to remove the paper after only about 50 sheets. Change to 1 or 0 if its on 1 going from memory is in ACC level 2 look for something like FIN-STP cant remember the exact one but you'll find it.
    • madas
      • Aug 2008
      • 313
      Cheers copier tech I will take a look and post results.
      I forgot to mention they take the paper off the finisher and I think its only a few pages?
      Les
        Product : image RUNNER ADVANCE C5030 / C5035 / C5045 / C5051
        Internal Finisher-A1
        A Message of 'Remove
        Paper From the Finisher' is Displayed, After Running Only
        Fifteen Sheets of Large Size
        Paper Problem :
        The message
        remove paper from the finisher would come up on the display after
        running fifteen large size copies ( LGL-11X17). LTR size
        paper seemed to work fine.
        The machine would not continue running any jobs until the
        paper was removed. After
        checking the
        paper surface sensors PS11 and PS12, it was noticed that the finisher
        paper tray was a little crooked. Since the tray was crooked it did not allow the proper
        height of the stack to be detected correctly. Solution :
        The finisher tray was realigned so that is was straight and level. One side of the
        tray was off by one tooth. In this case, leveling the tray resolved the issue.
        STPL-MAX Set of max number of sheets for staple
        Lv.2 Details To set the maximum number of sheets to be stapled in the Finisher.
        When “1: 60 sheets” is set, the stapling capacity becomes 60 sheets.
        Adj/set/operate method 1) Enter the setting value, and then press OK key.
        2) Turn OFF/ON the main power switch.
        Display/adj/set range 0 to 1
        0: 50 sheets, 1: 60 sheets
        Default value 0
