canon ir2520 send to email
  • mramlawi
    • Jul 2011
    • 838
    dears,
    can any one send me how to setup email on ir2520i using gmail and for other domains
    Distinguished road makes you jewel in rough
  • teckat
    • 16083
    Re: canon ir2520 send to email
    Originally posted by mramlawi
    dears,
    Yahoo and Gmail service providers require email clients (for example Outlook Express) to authenticate via SMTP port 465 with secure communication (SSL).
    The issue is when the exact same configuration information is transferred from email clients to Canon devices, customers cannot send email.
    The result is error code #839. The reason for this is Canon devices do not work when port 465 is used for SMTP transmission. Port 587 has to be configured on the machine for send via e-mail to work.
    To resolve the issue, SMTPTXPN option has to be changed in Service Mode level 2 to 587 and Canon devices must be configured to authenticate via SMTP with SSL enabled.
    - Access Service Mode level 1 by pressing Additional Functions, - 2 and 8
    - Access Service Mode Level 2 by pressing Additional Functions - Additional Functions - 2.
    - Once you are in Service Mode level 2, select Copier > Option > Body > SMTPTXPN, enter 587
    - Select OK and recycle the machine to apply the change.
    After machine recycle, select Additional Functions > System Settings > Network Settings > Email/I-Fax.
    - Depending on which service providers you have, enter smtp.att.yahoo.com or smtp.gmail.com for SMTP server
    - Enter a valid user e-mail account for E-mail Address.
    - Select Authent./Encryption > SMTP Authentication (SMTP AUTH) - On
    - Set Allow SSL (SMTP Send) On.
    - Select OK to apply the changes.
    - Access Network Settings and make sure IP address, Gateway, DNS settings are correctly entered. (These information can be obtained by using a customer's networked PC nearby, access the command line, enter ipconfig /all.)
    - Restart the Canon device and start sending e-mail once it is Idle.
    • mramlawi
      • Jul 2011
      • 838
      Thank you , but in ir2520i theres no level 2 !?
      • teckat
        • 16083
        How To set up the Scan to E-mail---see link
        • copier tech
          • 8169
          Point to note!
          Sending an e-mail or I-fax is available only when the Color Send Kit-Y1 (optional for the imageRUNNER 2545/2535/2530/2525/2520) is activated"
          • teckat
            • 16083
            Point to note!
            Good point, wish posters would state all the facts on their printers.
            • mramlawi
              • Jul 2011
              • 838
              Point to note!
              but the machine is i version isnt mean its activated ?
              • dan7777
                • Dec 2012
                • 680
                http://www.copytechnet.com/forums/ca...ing-email.html
                • Rakesh
                  • May 2012
                  • 72
                  https://www.dropbox.com/s/5xwxn7jdmp...-Mail.pdf?dl=0
                  above-link-is-not-available.
                  View Life As A Continuous Learning Experience...
                  • teckat
                    • 16083
                    iR2545i Series--Systems Settings Guide Part_1.pdf
                    iR2545i Series--Systems Settings Guide Part_2.pdf
