IRC 5250 is there level 3?
  • teckat
    • 16083
    #16
    Re: IRC 5250 is there level 3?
    Originally posted by Zela
    From level1 press 139 * at the same time
    post from > 12-23-2016
    • dekoster
      • Aug 2012
      • 84
      #17
      Originally posted by gtr5320
      IRC 5250 is there service mode level 3?
      How to enter?
      PLEASE
      level1 dann *19 dann 3
      • Cipher
        It's not easy being green
        • May 2006
        • 1309
        #18
        Well take me to the next level.
        Interesting.
        • teckat
          • 16083
          #19
          • Cipher
            • May 2006
            • 1309
            #20
            Disappointing, no self-destruct button.
            • teckat
              • 16083
              #21
              All imageRUNNER ADVANCE Series / All imagePRESS Series / All imageRUNNER Series
              August 9, 2016
              Error :
              E350, E355, or E748 error codes are displayed on the machine.
              Counter PCBs and SATA Flash PCBs are no longer available for purchase.
              As a result, please handle E350 / E355 and E748 in the following manner:
              E350 /E355 Error Codes:
              Call the Technical Support Center (1-800-528-2830).
              E748 Error Codes:
              *NOTE 1: For any of these error codes, do not swap any PCB's from any other machine. Doing so may render both machines unrecoverable.
              *NOTE 2: Do not use any of the User Mode or Service Mode clears when encountering these error codes.
              Executing the Service Mode or User Mode clears may render the machine unrecoverable.
              • copier tech
                • 8193
                #22
                Press Settings/Reg button
                #1-#7 same time
                then #3-#9 same time
                then Settings/ Reg again ( this needs to be done quickly)
                • Canuck
                  Tech Specialist
                  • 1713
                  #23
                  Originally posted by zoraldinho
                  Are you bored? What the f.. do you won't from me?
                  WTF your problem? You tell him to initialize all data for what? That will wipe out all user settings, network settings, everything. Bogus info.... Nothing says anything about fax in his post. And if it did have a fax issue, you do a Clear all in fax under service mode. Init all data could create him a headache if he did not print everything out. Not bored...just helping by not sending him down the wrong path. Init all data is the last thing you do..I would clear HDD image partitions first after an ALL CLEAR. Init is a last resort...sometimes necessary though I agree.
                  • dekoster
                    • Aug 2012
                    • 84
                    #24
                    This I know, I just want to know how to enter level 3, manuals are not mentioned, I want to upgrade the technology,please tell me
                    *2&8
                    modelist
                    *1&9 then 3
                    • dekoster
                      • Aug 2012
                      • 84
                      #25
                      *2&8*
                      modelist
                      *1&9 then 3
                      • teckat
                        • 16083
                        #26
                        *2&8*
                        modelist
                        *1&9 then 3
                        no reason to enter a Level 3
                        if u want a BRICK for a Printer
                        • copier tech
                          • 8193
                          #27
                          Or to reset the main counter 🤔
                          • dekoster
                            • Aug 2012
                            • 84
                            #28
                            How to enter?
                            PLEASE
                            *2&8*
                            modlist
                            then *1&9 then 3
                            • dekoster
                              • Aug 2012
                              • 84
                              #29
                              if you have questions
                              write me PN
                              ddk@ajruli-Kopiersysteme.de
                              • dekoster
                                • Aug 2012
                                • 84
                                #30
                                Originally posted by V-P
                                Even if you get there (Level 3) - there is not much to be understood. Just a bunch of numbers on a screen.
                                Myself - I prefer the level 4 (Magician Level)
                                what is level 4 ???
