Error Code E000024-0001 on Canon IR3570
  • princepriyu
    • Aug 2025
    [Error Code] Error Code E000024-0001 on Canon IR3570
    hi all
    i am facing an error
    code :- E000024-0001
    i am using canon IR3570
  • bobburnsreb
    • Mar 2015
    • 233
    Re: Error Code E000024-0001 on Canon IR3570
    Found this tech pub. Other discussions pointed towards the toner sensor.
    • princepriyu
      thanks a lot for your help
      previously the error E000024-0001 immediately appeared after 1st print
      i cleared the error from service menu (by pressing aditional function > 2+8> function>clear>err) and restarted the machine
      again after printing 1st copy it gives the same error
      i'v emptied the developer unit with removing all tonner, removed the sensor, wiped with dry cloth, reassembled it,
      tried to install tonner by service menu (by pressing aditional function > 2+8> function>install>tonner)
      but it says NG (i guess NOT GOOD)
      even after i try after clearing the error it .....
      now friends
      a new error immediately after machine is restarted
      E000024-0000
      i'm completely depressed
      what should i do to correct it and make the machine working
      • CS0523
        • Feb 2015
        • 35
        First: Did you use Genuine Toner ?
        I fix this error many times. I mill/rasp the sensor mounting area on the developing assembly (remove the "ring" and the srew-holes)Unbenannt.jpg
        when I do this the sensor goes furhter into the dev. assembly.
        You can do this or buy the new model FM2-0287-000
        • princepriyu
          i used the same toner that i'm using since 7years,
          same brand, same vendor to the machine.
          yes.. its not genuine canon
          but i never faced this kind of error since my purchase of the machine till date.
          • princepriyu
            HURRY
            PROBLEM SOLVED
            i found two wires which are connected to toner sensor on the developing unit were broken, i had to trace it by checking the wiring diagram, because all the wires are YELLOW colored,
            changed all the five wires with new.
            problem solved.
            • mehta
              • Oct 2010
              • 11
              now friends
              E000024-0000
              You try dccon err inservicemode .
              • copier tech
                • 8172
                This issue was resolved way back in February, see above!!!!!
