please HELP..... IR4570
  • jhoowel28244
    • Oct 2012
    • 9
    [Misc] please HELP..... IR4570
    Please see attachment...
    our machine is IR4570...
    thanks...
  • rudysemira
    • Oct 2016
    • 108
    Re: please HELP..... IR4570
    thanks...
    if you used not genuine toner sometimes we have encountered trouble from the print quality, try to clean the developer unit remove the toner and clean the developer toner sensor.......
    • jhoowel28244
      • Oct 2012
      • 9
      thanks...
      i will try to clean the developer toner sensor...
      bdw... im not a technician... our service technician always busy, working other machine...
      thank you again rudysemira...
        • 8172
        Looking at your sample I can see the registration is slipping slightly, you could try to clean the registration roller (long hard gray rubber roller in the right hand door) if this does not work then you will need to replace the registration clutch.
