please help regarding the error which is shown in pictures
[Misc]
while coping some times the print are not good please help regarding the problem weather it is scanar problem or mother board or any thing else in canon ir 3230
thanking you
Re: please help regarding the error which is shown in pictures
Originally posted by Brian8506
Looks smeared. Fuser film? If not smeared then how about the drum
Yeah, poor fusing. Does the toner wipe off? =^..^=
Sir, try the test print in service mode if the output is same as your sample copy the drum and fuser is the problem.... If the test print is good the CIS or the flat cable would be the problem.
drum is changed yesterday and test print is good no any defect and also no any problem from p c print and no matter how much copy but in photocopy it occurs after 100 photocopy and no problem to 30 or 40 copy. no any fuser problem and no any problem in flat cable and not sure about cis
What media type? =^..^=
Run a copy thru the bypass and set your paper setting to heavy bond paper, and run a regular 20lb sheet thru, if its good, then you know its fuser problem, like its being suggested, have seen this before, its more likely fuser.
