ITB and Cleaning Blade Renew on C5240
  • maximilian500
    • Aug 2016
    • 67
    Hello everybody,
    I am to replace the ITB with a C5240. This makes probably on all sides gladly times a small magenta point at the end of the page. In the manual, this is to be taken when changing the Cleaning Blades Tospearl 240 FY9-6007. Do you do this, or can you take toner for it. On other machines is synonymous ultimately also toner taken? How do you do this, or what else?
    Yours sincerely and thank you
    Maximilian500
  • madas
    • Aug 2008
    • 313
    Re: ITB and Cleaning Blade Renew on C5240
    Hi maximillian500
    Im not quite sure what you mean, no offence to your English.
    So if you are replaceing the belt and Cleaning blade/unit you need to lubricate the belt with either setting powder as I know it or you could use toner if nothing else available or even waste toner.
    Hope this helps
    Les
    • maximilian500
      • Aug 2016
      • 67
      Originally posted by madas
      Hi maximillian500
      Hope this helps
      Les
      Right, I would like to replace the transfer belt and the cleaning blade. Here in Germany, however, Tospearl 240 is largely unknown and therefore the question of what else can be taken. So old toner can be taken without hesitation?
      • guitar9199
        • Sep 2016
        • 1100
        If I ran out of drum setting powder, I found a good substitute to be a Bowler's "Slide Powder".... It's usually available in a local bowling alley.
        Here's a link to the one I used recently. https://www.amazon.com/Ebonite-AR312.../dp/B000MEEDT8
        Good luck.
        • Harry
          • 228
          Use Katun Kynar Dusting Pouch PN 707200
          Gruss Harry
          • madas
            • Aug 2008
            • 313
            Yes you can, ive used it in the past and thats what the cleaning blade removes toner!
            • maximilian500
              • Aug 2016
              • 67
              A colleague said that he did not use anything. The original cleaning wipers already have enough powder from the delivery on it.
                I bit of old toner wouldnt do any harm.
                When re assembling, make sure the handle is pushed up against the ITB frame, make sure you get the circlip in the groove
                • maximilian500
                  • Aug 2016
                  • 67
                  In the meantime I have replaced the ITB and the Cleaning Blade.But now I have the same problem as with the C5030 in this post: http://www.copytechnet.com/forums/ca...ight=Gray+veil
                  Has one an idea why the letters now also shaded gray?
