Second side of original is lighter and blurry
  • V-P
    • Apr 2011
    • 679
    [CQ] Second side of original is lighter and blurry
    On a iR8295 machine when I scan from ADF (2-sided original) - the second side of the page comes out blurry and lighter.
    It is not printer issue - it occurs on scanner.
    It does not happen from glass - only from ADF.
    I have cleaned everything.
    What am I missing ?
    Thnx,
    • 23009
    Re: Second side of original is lighter and blurry
    On most single scan document feeders the first side is scanned by the CCD through the slit glass, and the second side is simultaneously scanned by a CIS in the DF. The CCD can produce a much better image in most cases than the CIS, so often a quality difference is noticeable. I would not be a bit surprised if Canon had some special test patterns to calibrate the image quality for both the CCD and the CIS. You might take a look in your service manual. =^..^=
    • MunsterTech
      • Sep 2014
      • 381
      not sure on that model but cant you go into CCD adjust and do DF-WVLgth 1 and 2, 1 works from the glass and 2 works from the DADF, i find that it works great on some IR machines to improve quality
      • dan7777
        • Dec 2012
        • 680
        What am I missing ?
        Thnx,
        If it is a dirty/dusty environment you need to take the second side scanner out of the adf and clean. Not very hard to do. Take it out from the top. Clean the mirrors or you may need to replace it if it is bad. All mine I cleaned. It throws a code when it gets real dirty.
        • Canuck
          Tech Specialist
          • 1713
          Clean the read glasses then do your CCD ADJ, white levels 1,2,3 and 4..
          • V-P
            • Apr 2011
            • 679
            Ok - apparently the inner mirror (side mirror) inside the cis was very dusty.
            I did clean all the glasses (also my glasses )
            It is looking better now.
            Thnx fellas !
