IR3100CN Show " Remove the paper from the output tray"
  • phollawat Chaimoonchuen
    • Dec 2007
    • 71
    I have problem about Canon IR-3100CN.
    1. It`s show " Remove the paper from the output tray". I check the paper all output tray, no have paper.
    2. How, I want adjust color in correct.
    Please help me.
    Wat
  • smiley
    • Aug 2008
    • 615
    do your machne has finisher?
    there is no glory without sacrifice
      • Dec 2007
      • 71
      Yes, I have.
        • Dec 2007
        • 71
        Originally posted by phollawat Chaimoonchuen
        Yes, I have.
        Sory! No have
        • Oze
          Ricoh Fanboy
          • Jul 2008
          • 1663
          The buffer pass unit is unplugged.
          Did you just purchase the machine?
          If so then it DID have a finisher at some stage but they removed the buffer pass unit and forgot to change the setting under "ACC" in SERVICE MODE.
            • Dec 2007
            • 71
            Please tell me step by step again.
            Thank You.
            • br21
              • Jan 2008
              • 22
              I've got same problem in same machine.
              It probalbly was machine with finisher unit some time ago, but currently is without finisher, ACC in service mode OUT-TRAY set "0", surely no paper stuck, and constantly same information "remove..."
              where to look for solution?
              • Oze
                Ricoh Fanboy
                • Jul 2008
                • 1663
                Has the machine been working ok up til now..or did you only just get it?
                • SCREWTAPE
                  • Jul 2025
                  It probably was machine with finisher unit some time ago, but currently is without finisher, ACC in service mode OUT-TRAY set "0", surely no paper stuck, and constantly same information "remove..."
                  Do the following :
                  1. Enter Service mode by *28*
                  2. Hit Copier
                  3. Hit Option
                  4. Hit ACC
                  5. Hit Out-Tray and set to a 1
                  6. Hit the OK button
                  7. Power the unit off/on with the main power switch on the right hand side of the unit.
                  Or, do you have an internal finisher built in?
                  If so check the Lower Limit Sensor PI9.
                  In case its faulty here is the part Number for PI 9 is WG8-5696-000.
                  • br21
                    • Jan 2008
                    • 22
                    I found a solution. It was black piece of plastic missing which caused all the problems
                    • ennier
                      Re: IR3100CN Show " Remove the paper from the output tray"
                      friend could tell me what is that black piece of speech that I have the same problem and I throw final error 020 ..
                      • copier tech
                        • 8156
                        Start a new thread & include the FULL error code eg. E020-XXXX
