IR Adv 8105 E001-002 on A5, B5 and A4-R
  • tinnyjay
    • Oct 2009
    • 663
    Hi!
    Today i am facing a strange problem with my machine.
    Printing in A4 and A3 i dont have any issue, but printing small formats like B5, A5 even A4-R, machine after 2-3 minutes on printing, shows me E001-002.
    I changed the main thermistor but nothing new.
    Temperature on main thermistor shows 192-202 grade celcius (when printing) but in edges of fuser roller, sub-thermistor goes fast to 230 grade celcius and i got the error code.
    Checked and inspected but could not find any issue physically.
    Any help i'll appreciate.
    Thank you
    "Who loves the roses,must also bear thumbs"
  • copier tech
    • 8174
    Re: IR Adv 8105 E001-002 on A5, B5 and A4-R
    Replace the sub thermistor as like you say that is the one giving the false reading.
    • tinnyjay
      • Oct 2009
      • 663
      I swaped thermistors and its the same ... still Fix-UE reading high temperatures.
      • David Morrison
        Digital Tech II
        • Feb 2010
        • 43
        I got an E001-0003 for a fixing film that wasn't seated properly. I know your code is different, but still maybe worth checking?
        Sent from my SM-P580 using Tapatalk
        • David Morrison
          Digital Tech II
          • Feb 2010
          • 43
          Oh wait, that doesn't have a film, does it? Wrong machine.
          • aco.bk
            • Sep 2012
            • 130
            Using OEM or Compatible upper roller????Already see that on NonOem roller.
            • copier tech
              • 8174
              I agree, if you have replaced (or swapped) all thermistors then i'd look at the fixing roller, especially if it's non OEM!
              • rudysemira
                • Oct 2016
                • 108
                have you check the thermostat? thermostat it can also control the heat temperature if overheat detect from hot roller that is automatically switch off do not just focus on thermistor, the two parts was designed to protect for overheating......
                • dan7777
                  • Dec 2012
                  • 680
                  Originally posted by tinnyjay
                  Hi!
                  Thank you
                  I had a 8295 I had to replace the top half of the fuser twice for E001 codes (don't remember the sub code). Tried thermistors and same problem.
                  • roho
                    • Mar 2009
                    • 844
                    Normally if the shutter was a issue you would get a dedicated error, but considering it's smaller sizes I'd consider that as well.
                    • Canuck
                      Tech Specialist
                      • 1713
                      8105 has no shutter...ends are overheating on small stock.
                      • Canuck
                        Tech Specialist
                        • 1713
                        Totally incorrect....thermostat will open if over heated. NO EFFECT ON TEMPERATURE CONTROL AT ALL. If it opens it will not reset by itself and machine would be down...service mode reset will not fix it in this case. To reset thermostat,stick it in the freezer for a while then smack it with a screwdriver handle. Been resetting them like this for 25 years.
                        • PCC.TONER
                          • Mar 2017
                          • 13
                          why error: E001-002
                          Fixing Assembly high temperature error (software detection). The Fixing Main Thermistor (THM1) detects 230 degC or higher. The Fixing Sub Thermistor 1 (THM2)/Fixing Sub Thermistor 2 (THM4) detects 230 degC or higher for 2 consecutive seconds.
                          Solution:
                          1. Check if the cable of the Thermistor is caught. -> Replace the Thermistors. -> Replace the Fixing Assembly. 2. IH control error. -> Replace the Fixing Power Supply PCB (PCB10), the DC Controller PCB (PCB1), or the Main Driver PCB (PCB2).
                          Hope it is useful for you.
                          Linda
                          china spare part, Toner chip, Copier parts, Toner Cartridge - einmay toner
                          • tinnyjay
                            • Oct 2009
                            • 663
                            Non oem roller was the problem! Learned something new
                            Thank you all!
                            • tinnyjay
                              • Oct 2009
                              • 663
                              Originally posted by MaryB
                              Should check on epartsroom they have remam fixing assembly OEM or used
                              Thank
                              you
