Auto-gradation with imagepress C800
  • khattab.al.masry
    • 212
    [Misc] Auto-gradation with imagepress C800
    Dears all:
    I faced problem that when doing autogradation with imagepress C800 the following message appear
    "Adjustment was canceled . try again"
    i try again and again the same result
    by taking in consideration that we maintain our machine in care and well.
  • khattab.al.masry
    • 212
    Re: Auto-gradation with imagepress C800
    Dear all:
    we found the following attachment we hope to be useful.
    • teckat
      • 16083
      Originally posted by khattab.al.masry
      Dears all:
      Change the tray output selection for the gradation test print./ change it to test another location
      Check the output sensor for selected location. > sensor flag could be hung up
      • seniortech
        • Dec 2007
        • 180
        Make sure that you run Autograd using a generic type media for instance A3/SRA3. If the paper in the cassette that you are using has a custom name or settings applied for instance you have renamed the paper in the cassette; 'Special Paper' Autograd will generally fail.
        • khattab.al.masry
          • 212
          We did not use finisher
          Just output tray is installed
          Sent from my SM-J700H using Tapatalk
          • Leanderson
            • Apr 2022
            • 1
            Dear all:
            Eu estava com esse problema e resolvi inserindo os valores de etiqueta P-Pascal
            • zoraldinho
              teacher-guide-expert-guru
              • Mar 2008
              • 5015
              Dirty sensors.
              Old itb
              • bobburnsreb
                • Mar 2015
                • 233
                The patch sensors read out at the 18 inch area. Check your color drums at the edges.
                • teckat
                  • 16083
                  Post was from 2022
