where can i get sst+firmware for ir2200 and ir2200n
  • ids_73
    • Jun 2011
    • 16
    hi there can some one give me the sst and firmware for ir2200 & ir2200n
    also i am looking for instraction of how to do the installation on them on a new hd
    thanks in advance
  • teckat
    • 16083
    Re: where can i get sst+firmware for ir2200 and ir2200n
    thanks in advance
    iR 3300/2800/2200 has the 2200n included.
    • joejoefta
      same here, how can I get sst + firmware for ir2200 and ir2200n. Please message me. Thanks for helping
      • teckat
        • 16083
        iR2200n ?
        what print kit is installed
        • joejoefta
          Getting error: Please check your file *.ift. HDD-Model:FUJITSU MHV2040AH. Check *.ift and this HDD is not in the file. Does anyone have a file that will support this HDD?
          • copyman
            Owner / Technician
            • Sep 2005
            • 4735
            Much easier to buy the HDD with the system software already installed. Some places sell with it pre-installed. Or buy a used HDD on ebay "that was removed from a IR2200". Just swap out the HDD and good to go without doing anything else.
            It is a pain to do because you need laptop with old parallel port to install software.
            • copyman
              Owner / Technician
              • Sep 2005
              • 4735
              I have a HDD that I removed from a working 3320G and was going to put on Ebay. Think it has the boot rom with it. If you need it and are in USA PM me. I think the HDD is same as IR2200 but system software may be different.
              • teckat
                • 16083
                Try Modifying the HDDDescriptor File
                • copier tech
                  • 8188
                  Yes you can modify the HD format file, or source a HDD from this list as used to do back in the day!
                  You will need an old laptop with a parallel port to install the system software.
                  HDWN 'FUJITSU MPC3032AT
                  HDWN 'FUJITSU MPD3043AT
                  HDWN 'FUJITSU MPE3064AT
                  HDWN 'QUANTUM FIREBALL CX6.4A
                  HDWN 'QUANTUM FIREBALLlct10 05
                  HDWN 'QUANTUM FIREBALLlct08 04
                  HDWN 'QUANTUM FIREBALLlct15 07
                  HDWN 'FUJITSU MPF3102AT
                  HDWN 'TOSHIBA MK6014MAP
                  HDWN 'TOSHIBA MK6015MAP
                  HDWN 'IBM-DJSA-205
                  HDWN 'IBM-DARA-206000
                  HDWN 'FUJITSU MHK2060AT
                  HDWN 'ST34311A
                  HDWN 'ST34313A
                  HDWN 'ST310211A
                  HDWN 'FUJITSU MPG3102AT E
                  HDWN 'QUANTUM FIREBALLlct20 10
                  HDWN 'TOSHIBA MK1016GAP
                  HDWN 'IBM-DJSA-210
                  HDWN 'IC25N006ATDA04-0
                  HDWN 'FUJITSU MHN2300AT
                  HDWN 'TOSHIBA MK6017MAP
                  HDWN 'IC25N010ATDA04-0
                  HDWN 'Maxtor 2B020H1
                  HDWN 'MAXTOR 4K020H1
                  HDWN 'IC35L040AVER07-0
                  HDWN 'WDC WD300AB-00BVA0
                  HDWN 'IC35L020AVER07-0
                  HDWN 'SAMSUNG SV2001H
                  HDWN 'Maxtor 2F030J0
                  HDWN 'ExcelStor Technology J120
                  HDWN 'SAMSUNG SV0211H
                  HDWN 'IC25N010ATCS04-0
                  HDWN 'ST340015A
                  HDWN 'TOSHIBA MK2023GAS
                  HDWN 'IC25N020ATMR04-0
                  HDWN 'SAMSUNG SV0221N
                  HDWN 'FUJITSU MHT2020AT MF
                  HDWN 'ST92011A
                  HDWN 'SAMSUNG SV0411N
                  HDWN 'HDS722540VLAT20
                  HDWN 'ExcelStor Technology J640
                  HDWN 'Maxtor 2F040L0
                  HDWN 'SAMSUNG SP0411N
                  HDWN 'WDC WD400BB-22HEA0
                  HDWN 'WDC WD400BB-22JHC0
                  HDWN 'HDS728040PLAT20
                  HDWN 'ST340014A
                  HDWN 'TOSHIBA MK4032GAX
                  • joejoefta
                    Successfully formatted HDD after editing the *.ift file to include the HDD.
                    • teckat
                      • 16083
                      I'll take a six pack of Dark IPA, not sure what copier tech enjoys.
                      • copier tech
                        • 8188
                        Good work.
                        Shame this is not possible on the later Canon kit.
