Canon IR2200
  • tcypy1961
    • 773
    [Error Code] Canon IR2200
    E007 most likely causes??? (the Fixing film ass'y, fuser sensor flag, or something within the fuser ass'y) the only parts I see available from Precision Roller,
    Thanks!!!
  • copier tech
    • 8164
    Re: Canon IR2200
    Yes it will be the fixing film, they can tear or the grease drys out over time.
    E0007 is a fixing film rotation error.
    • JParker
      Technician II
      • Jul 2015
      • 51
      Re: Canon IR2200
      Agreed! I just replaced a film on this model 2 days ago for e007 & it resolved.
      • jper34
        • Sep 2011
        • 225
        Re: Canon IR2200
        Yep...replace the fuser belt, be sure to clean heater , an bushing ends real good, and re-grease...pretty simple once you do a few times...good luck mate
        • tcypy1961
          • 773
          Re: Canon IR2200
          I go back out to the copier and pull the fuser unit again (I'm not a fan of Canon copiers and thus don't know a lot about them) other than the 225,000+ copies made on copier to me the fuser belt looks good and it turns when rotating the gears. I relube the bushings and belt(did not clean the heater) re install the fuser and made 50+ copies before the error code came back??? Still the fuser belt ass'y???
          Thanks!!!
          • JParker
            Technician II
            • Jul 2015
            • 51
            Re: Canon IR2200
            You can check the fixing drive unit if the fuser is functioning normally when manually manipulated. Likely still a fixing film issue though.
            • Northwestservice
              • Jan 2011
              • 140
              Re: Canon IR2200
              the drive for the fixing film comes the rubber ring on the rear end of the lower pressure roller replace the rubber ring and or the lower roller and your problem will be gone. in an emergency you can clean the rubber ring but at 225,000 it needs replacement the part # is RB2-1920
