void going thru black
  • dsutton13
    • May 2017
    • 7
    [CQ] void going thru black
    i know dev/drm would be first assumption. but look at PGs. pg5/15 you see void. pg10 looks fine. ????
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5015
    Re: void going thru black
    Printer Model??
    It's look like black developer.This is standard issue where the problem is visible only on the halftone.PG-10 is 100% cover.
    • dsutton13
      • May 2017
      • 7
      Originally posted by zoraldinho
      Printer Model?? iradv c5035.
      iradv c5035. another tech went out for the same thing not long ago and did change dev/drm. still getting this. visually inspected dev, ran cln function. weird.
      • JParker
        Technician II
        • Jul 2015
        • 51
        Has the laser been cleaned?
        • dsutton13
          • May 2017
          • 7
          yes it has.
          • madas
            • Aug 2008
            • 313
            Had similar and had to take laser units out in the end and open it up and clean the mirrors manually, in a metal factory. So if you are in a dusty enviroment and only used the blue cleaner I would check that, same model by the way.
            Hope this helps
            Les
            • zoraldinho
              • Mar 2008
              • 5015
              If you still getting this with new developer then clean laser assy must resolve the mystery.If you can make the force stop and check image on the drum and belt to eliminate the doubts between laser and transfer.
              • petermays
                • Mar 2017
                • 91
                hi..thats inside your laser.the lens is dirty.
                boy the cq you have on all colours is bad.rep the drum kits.and clean charge rollers.
