Canon iRC2880 toner feed issue E020-200
  • foundry
    • Apr 2011
    • 20
    Looking for experience. Toner feed motor was not feeding toner as well as not functioning in test mode. Driver board was replaced and all was good until now.
    Appears that toner is once again not feeding and I am looking for some experience out there.
    Any input greatly appreaciated
    One Look is worth a thousand guesses
  • copier tech
    • 8169
    Re: Canon iRC2880 toner feed issue E020-200
    Most likely the toner hopper motor has failed & is shorting out the board you replaced!
    • foundry
      • Apr 2011
      • 20
      Thanks for the assist..... Strange though a short. Haven't seen a motor short on a copier in all my 30 plus years. I'll check just the same.
