Canon ir adv 8105 no power at Ethernet port
  • rudysemira
    • Oct 2016
    • 108
    #16
    Re: Canon ir adv 8105 no power at Ethernet port
    Originally posted by amitlama_78
    hi
    I sometimes do get Ethernet status light on router when my machine is turned on but does not connect......
    when turn off the machine and turn back on Ethernet status light is gone and after an hour or so i do get the status on Ethernet port......
    I too think its an software issue...........
    so how do reset settings............. and if i do all data initialize do i have to backup data and how to back up my data?
    do you know how to enter service mode?
    go to service mode *28* then select copier>display>acc-sts look if the nib is 0-not connected 1-connected check the status....
    • rudysemira
      • Oct 2016
      • 108
      #17
      [QUOTE=amitlama_78;569263]hi
      you need to assign higher number to your machine if the ip address from your router is dhcp and that machine never been opened for long days other device may get the ip address so that will be happened to conflict, try using your laptop to ping the machine you only have to do is set manually put ip address static to your laptop sample ip is 192.168.1.10 then to your machine is 192.168.1.11 same static address....then ping it
      • copier tech
        • 8103
        #18
        [QUOTE=rudysemira;569265]
        hi
        Poster tried connecting laptop directly so has ruled out any network or IP conflict issues
        • amitlama_78
          • Oct 2009
          • 62
          #19
          hi
          checked on service mode acc-sts nip is 1
          • rudysemira
            • Oct 2016
            • 108
            #20
            [QUOTE=copier tech;569269]
            yes i read the poster but you cannot detect other device if you cannot configure your laptop manually.........using lan cable not usb cable.........
            • JPiek
              • Oct 2014
              • 435
              #21
              An IP conflict doesn't cause a Link to go down, the Link-led would be lit anyhow.
              OP seems to be able to ping 127.0.0.1 ? So the Copier can ping itself.
              I suspect a fauly port/RJ45 on the NIC, i mean, the physical connection to the network, not the NIC's electronics. His router sometimes gives a link-status, that would support the fault RJ45 connection theory..
              Johan
              • amitlama_78
                • Oct 2009
                • 62
                #22
                [QUOTE=JPiek;569542]An IP conflict doesn't cause a Link to go down, the Link-led would be lit anyhow.
                yes i believe the same............. because ip conflict should not cause link led to go off...........
                can i repair the rj45 port.........
                • JPiek
                  • Oct 2014
                  • 435
                  #23
                  Check if the pins inside are bend or out of place, but you'll probalbly will have to replace the board containing the RJ45 port...
                  Johan
                  • amitlama_78
                    • Oct 2009
                    • 62
                    #24
                    hi
                    checked the pins its not bend or broken....
                    my machine is a RC machine and don't have licence key..... if i do all data initialize then do i need licence key.....
