Cleaning developing roller on a Canon IR2525
  • doug
    • Dec 2011
    • 198
    Good Afternoon,
    I have a customer that has a dark image on the copies on a Canon IR2525.
    I replaced the drum but the images were still there...seems like on the developing cylinder.
    Can I clean that? and how would you so as not to damage the developing unit?
    How would I do that?
    Thank you
    Doug
  • rudysemira
    • Oct 2016
    • 108
    Re: Cleaning developing roller on a Canon IR2525
    Originally posted by doug
    Good Afternoon,
    Thank you
    Doug
    can you send sample copy? did you ask if they used other type of toner....
    • roho
      • Mar 2009
      • 844
      I never clean the dev cylinder, it is either good or shot. I would be looking elsewhere for the problem. Is it a smear, streak, or offset image?
        • 23009
        Is it safe to guess that this Canon is monocomponent? If yes, what about mottling?
        Common on monocomponent developing, sometimes the toner clumps on the developing roller, especially during times of high humidity. Traditionally you would dry-wipe the developing cylinder with toner left in the unit. The toner just pushes out of the way. Keep wiping, rotating, wiping, rotating ... until you get all the way around.
        Aftermarket toner has a much worse problem with mottling. =^..^=
        • Canuck
          Tech Specialist
          • 1713
          Mono component Canon....I clean dev cylinders all the time. It was mandatory on NPs....just wipe them with clean dry cloth. If toner is baked to cylinder, scrape it loose with fingernail then wipe with dry cloth. Been doing this to Canon mono dev cylinders forever...older NPs I would wipe away toner coating and clean cylinder with Soft Scrub(except ones with black coating)
          • copier tech
            • 8174
            I would guess this poster is not using genuine toner, hence an issue with copy quality & the dev unit.
            • ARUN MISHRA
              • 80
              Change toner only
              sigpicARUN KUMAR MISHRA
              • petermays
                • Mar 2017
                • 91
                hi..normally with a generic toner the dev unit will cause a light image..then u would empty toner clean dev roller with a clean cloth and either add toner or put a new toner in and add.i have have the charge roller in the drum cause black marks.dark image what becomes lighter during the day.not sure if the problem is the same .try pls put a att image of fault..thank you
                • charles
                  • Jul 2017
                  • 8
                  Good Afternoon,
                  Thank you
                  Doug
                  change the toner and see that one too. I hard the same problem
