canon ir 9070
  • PEPELEMU
    Tech
    • Oct 2008
    • 38
    canon ir 9070
    The transfer charge is shorting out intermitant. I get a e00069 error intermitant. I replaced the sep/transfer ass'y, still have problem. Copies have 1-2" light print across page. Ran machine with front door open and can not see any shorting out.
  • Paul 75
    • Oct 2008
    • 97
    Could be a couple of things:
    E069 - Have you replaced the upper fuser roller recently, if you have check the bushings are in the right way round, and plastic collar isn't broken Did you replace t/sep with pt no FM3-0455-010, this is the new correct part, check the wire cleaner isn't stuck in the middle of the t/sep unit(this will give light copies)
    Oh...... I can't copy at the moment then ? !!!!!!
    • PEPELEMU
      Tech
      • Oct 2008
      • 38
      Ir-9070 tansfer short
      Hi Paul, I did replace the upper roller and lower roller and bushings. I will check those. And Replaced the transfer with #fg68733020
      • Paul 75
        • Oct 2008
        • 97
        Check the bushes, they are both on the inside of the top bearings, I know this causes 069 cause Ive had it before.
        • 555
          • Jun 2008
          • 45
          behind the trans,sep assy. is a black plastic block with a metal pin sticking out of it which engages with the back of the machine. sometimes that plastic block gets cracked and needs to be replaced.
          • Oze
            Ricoh Fanboy
            • Jul 2008
            • 1663
            Wat 555 said...ditto ^_^
            • PEPELEMU
              Tech
              • Oct 2008
              • 38
              I took the fuser out and the back bushing broke off and there is a wire that looks like a groung that goes across the fuser bearing and that is off the bearing because the bushing broke. I ordered the bushing and will see if that fixes the problem
              Thank you
              • PEPELEMU
                Tech
                • Oct 2008
                • 38
                IR 9070
                Thanks Paul
                • PEPELEMU
                  Tech
                  • Oct 2008
                  • 38
                  ir 9070
                  That took care of the problem. The spacer bushing was broken on the upper fuser roller, and caused the ground on the fuser bearing to come off. Never would of thought of that.
                  • OtherTech
                    • Aug 2007
                    • 94
                    That is actually the bias for the fuser that comes from the transfer charger. Some have been known to disconnect the wire that runs from the connector behind/below the transfer charger. have had fuser pressure too tight and filings from bearings caused e069 codes.
                    • kmtech
                      • Sep 2008
                      • 125
                      Manuals parts Canon
                      I got a manual a while back from a fellow, I wana say manual4u, but I'm not real sure, any way I need a Canon IR 9070 Parts manual. I need to rebuild a fuser unit and need the parts #.
                      Thanks in advance
                      I'm at work if you could send the responses to there. allcarecopy@bellsouth.net. My home computer is down.
