Disabling Canon IR3045 Toner Sensor.
  • Shahn
    • Aug 2017
    • 30
    Is there any way to Disable Canon iR3045 Toner Sensor to ignore showing Replace Toner cartridge Message and keep printing even after toner gets over.
  • 20 year tech
    • May 2014
    • 577
    Re: Disabling Canon IR3045 Toner Sensor.
    Why would you want to do that ? do you want blank pages printing out ?
    • Shahn
      • Aug 2017
      • 30
      When it start shows replace toner cartridge.. it doesnt goes off even if i fill 300Grams of toner it goes only when i fill more than 600 - 700 grams of toner.. i feel its like Pain in @$$. BTW is it possible to do that?
      • 20 year tech
        • May 2014
        • 577
        No
        • techandtrader
          • Jun 2016
          • 335
          Wow just Wow! Our users just chuck a new toner in. No problem, its a machine...
          I have used Canon Imagerunner parts for sale. Most are floor model Color and / Advances Imagerunner with some 3025 3235 parts. Several intact machines being parted.
          • Ctl-Alt-Del
            • Jul 2006
            • 430
            But putting a whole cartridge in is too easy, much more challenging to spoon in a few hundred grams of magic dust that someone found on eBay.
            • aco.bk
              • Sep 2012
              • 130
              • copier tech
                • 8172
                What a stupid question to ask! This is a "technical" forum
                When you "spoon in" x ammount of toner into the bottle it is then feed into the hopper, if you are not spooning in enough to fill the hopper the "add tonner" message will remain.
                • Ctl-Alt-Del
                  • Jul 2006
                  • 430
                  I'm pretty sure Shahn is from India so he may need to be creative with Toner/Parts/Etc
                  That reminds me, What aver happened to my favorite Algerian SuperTech, Zaza?
                  • copier tech
                    • 8172
                    "Creative?" If you want to run a car you cant put less fuel in it, you can buy cheap fuel but still need the same ammount!
                    • JPiek
                      • Oct 2014
                      • 435
                      Right, creative with parts i can understand, got to keep it running. Creative with less toner i don't understand, you will need it to keep it running. If it's that hard to get: order more ahead...
                      Johan
