Canon c5051 to much magenta color
  • Mario
    • Sep 2017
    • 11
    Hello,
    I have Canon c5051.
    When I print with computer printer adds to much color magenta.
    When I gave the other developing and drum is the same problem.
    Change in service mode color on -8 magenta and cyan -5 yellow -3 gives a good picture.
    What I can do more for solution problem?
  • copier tech
    • 8193
    Re: Canon c5051 to much magenta color
    Hi,
    Are you using genuine Canon consumables?
    Have you run autogration?
    • Mario
      • Sep 2017
      • 11
      Yes, but before I has toner supply failure and dens was -7,3.
      Regulation vcont-m in service mode is good way to solve problem?
      • copier tech
        • 8193
        I would replace the magenta developer unit & drum to resolve this issue.
        • Mario
          • Sep 2017
          • 11
          I dont think so.
          When i changed parts to other machine after initialize have the same problem.
          I think machine have wrong values, tommorrow will be analized.
          Machine have Regulation, so i give a try it.
          • petermays
            • Mar 2017
            • 91
            hi..this is abit confusing..did you take ;parts to a diff mc and did the same or did you bring parts from another mc?if mc is giving you a -7.3(not enough toner in dev unit) in dens then the mc should go into E020 for magenta.did problem come when you replace any parts?pls load a pic of pg10 and a pic of print.
