IR Adv C7065
  • viczulis
    • Apr 2012
    • 52
    [CQ] IR Adv C7065
    Went to a machine with light copies from half way to back with black only. The drum and dev were way over on counts. Replaced drum ,dev,wire,grid, I am still getting light prints . What I don't understand is moving the prime wire up or down does not seem to change the density ????? Any other suggestions.
  • vigour
    • Aug 2010
    • 1038
    Re: IR Adv C7065
    Post a sample picture
    • zoraldinho
      teacher-guide-expert-guru
      • Mar 2008
      • 5015
      Re: IR Adv C7065
      copier>function>install>td-ac4
      • ReproKev
        • 273
        Re: IR Adv C7065
        I've had a similar problem that ended up being the grounding flanges inside the drum not making contact with the drum shaft.
        Pull out the drum and make sure the metal tabs inside near the rear are bent towards the center.
        • viczulis
          • Apr 2012
          • 52
          Re: IR Adv C7065
          OK I will try that I'm printing out using test patter 5 I just don't understand how moving the prime wire alot does not seem to make a difference on the prints
          • NorthW
            • Jul 2017
            • 55
            Re: IR Adv C7065
            Here's a few ideas, pull out the dev unit and see if it has an even coverage of toner, sometimes the black mylar strip can get caught, or in shipping the dev unit the starter mix can get shunted to one end, then just redistribute. Check that primary wire is in the notch on the posts. Look at transfer roller in itb, the pin can pop out. Clear your shading correction values just in case your customer was playing around in there too.
            • viczulis
              • Apr 2012
              • 52
              Re: IR Adv C7065
              Development unit seems fine the solids are really good like when doing test pattern 10 it looks good and solid fnt to back the issue is on gray scales
              • viczulis
                • Apr 2012
                • 52
                Re: IR Adv C7065
                Or is it 5 either way solids look OK
                • onlyinnewfoundland
                  • Apr 2013
                  • 235
                  Re: IR Adv C7065
                  Sounds like somebody messed with the shading correction...
                  Try going into settings/reg>adjustments/maintenance>adjust image quality>shading correct>visual correction
                  There should be a button to initialize it
                  Then try auto-correct color mismatch followed by full auto-grad.
                  I've had to reset the shading correction before even though it was all at zero anyway.
