Went to a machine with light copies from half way to back with black only. The drum and dev were way over on counts. Replaced drum ,dev,wire,grid, I am still getting light prints . What I don't understand is moving the prime wire up or down does not seem to change the density ????? Any other suggestions.
IR Adv C7065
Re: IR Adv C7065
copier>function>install>td-ac4If it ain't broke, don't fix it
A picture is worth a thousand wordsComment
Re: IR Adv C7065
OK I will try that I'm printing out using test patter 5 I just don't understand how moving the prime wire alot does not seem to make a difference on the printsComment
Re: IR Adv C7065
Here's a few ideas, pull out the dev unit and see if it has an even coverage of toner, sometimes the black mylar strip can get caught, or in shipping the dev unit the starter mix can get shunted to one end, then just redistribute. Check that primary wire is in the notch on the posts. Look at transfer roller in itb, the pin can pop out. Clear your shading correction values just in case your customer was playing around in there too.Comment
Re: IR Adv C7065
Re: IR Adv C7065
Or is it 5 either way solids look OKComment
Re: IR Adv C7065
Try going into settings/reg>adjustments/maintenance>adjust image quality>shading correct>visual correction
There should be a button to initialize it
Then try auto-correct color mismatch followed by full auto-grad.
I've had to reset the shading correction before even though it was all at zero anyway.Comment
