Corner of paper folded over Canon c7055
  • chrisio
    • Jul 2012
    • 104
    When printing long edge first the leading edge top corner is occasionally folded over. This doesn't happen every page and is printed over so I am assuming that it's happening as the paper is pulled from the decks. If I print short edge first it's perfect and I printed over 1500 pages this morning no problem.
    Any suggestions as to where I start looking please.
    Chris
  • teckat
    • 16083
    Re: Corner of paper folded over Canon c7055
    Chris
    _____
    Check the paper guide for burr
    • zoraldinho
      teacher-guide-expert-guru
      • Mar 2008
      • 5005
      Worn pickups or moist paper? This doesn't happen every page and this is usually problem.Otherwise i do a force stop and I identifying the location of the problem
      • petermays
        • Mar 2017
        • 91
        hi.easiset way is to stop mc at diff points and see at what point it folds.at pick up.....at pre reg unit....before fuser....after fuser etc. will break down your search but its most prob at pre registration.
        • chrisio
          • Jul 2012
          • 104
          when it happens - the corner has been printed over so I am assuming its happening before any image formation which only leaves the paper pickup side of things. I haven't checked yet to see if it happens out of all draws or just tray 3.
          EDIT:
          I have just checked and all drawers are fine EXCEPT the high capacity tray 1 - it happens on maybe 1 in 3 sheets but then it might run 5 sheets through fine. tested with an new pack of paper and also I used the same paper across the drawers when testing.
          I'm assuming this is something to do with the paper pickup/feed on this drawer?
          Cheers
          Chris
          • shooter
            • 6
            check the right side door hinges. if operator opens door too far, it can bend hinges so door will not close fully on rear upper area. corner will fold and get pressed by reg roller. check upper rear corner of door to see if it is flush with panel above it. most of them are a couple mm out, but if it is more, pull the hinge pins,and door, you will probably see deformation where the hinge bolts to frame of copier. compare the top to the bottom, usually the top is the one that needs reforming with a vice-grip. good luck
            • dan7777
              • Dec 2012
              • 680
              Chris
              Two things can cause this. One is in the fuser, full page color on 7265. We have only found setting the lead edge blanking to fix this. The other is it can happen in the reverse assembly (7055 and 7265). I usually also replace the door as a set. I have never seen why it happens there but the Mylar's get worn and the ends of the flags get worn causing jams. Since it is a 7055 I would replace the reverse assembly (and door if needed). I am fairly sure that will fix the folded edge, I seem to see this on the back edge (non operator side)
